You can also use the "reorder_matrix=yes" setting on the Simulation->Options->Analog to force the matrix to be rebuilt from scratch.
Netlist->Create uses the incremental netlisting, and only recreates the netlists for blocks which have changed since the last time they were netlisted, and then reassembles the complete netlist from these netlisted pieces (in the ihnl dir). Netlist->Recreate forces it to recreate the netlist for every single cellView, regardless of whether it needs to or not. The latter forces
the simulator to restart, rather than starting from where it left off. Netlist->Create will only tell the simulator to restart if one of the sub-netlists got recreated.
In older versions (before reorder_matrix came in), you can also use:
Code:envSetVal("spectre.envOpts" "controlMode" 'string "batch")
to tell ADE to restart spectre after each point in a parametric sweep. However, this won't help with a sweep performed on the pss form itself, since that uses a spectre built-in sweep.
