Jul 2nd, 2025, 8:57am
Help on matlab "a2d conversion" (Read 3020 times)
neoflash
Mixed-Signal
Designer
Oct 01st, 2006, 6:50pm
Hi, folks:
I have a waveform from analog simulator, both time and voltage values are stored in a text file. The signal represented is a digital "1,0" stream.
What wanted in matlab processing is the digital information carried in. How to convert them into a stream of one zero digital symbols, without so much useless overhead?
thanks,
Neo
haikom
Re: Help on matlab "a2d conversion"
Reply #1 - Oct 4th, 2006, 12:42pm
are you using the Cadence Simulation Environment? If yes, there is a new interface between Matlab and Cadence's simulation tools: http://www.mathworks.com/products/connections/product_main.html?prod_id=639&prod...
If no, I would try to get a cvs format out of the simulaor and then it is possible to read this data in Matlab or Excel.
You can also write a matlab script, which parses the result file and generates the matlab vectors.
Please specify the tools you are using. Maybe it is then easierer to help.
Kind regards,
haikom
View Profile haikomo   IP Logged
sck236
Reply #2 - Oct 4th, 2006, 9:41pm
Use dlmread function in MATLAB with a delimiter as "".
M=dlmread(filename,"",R,C)
, where R and C specify the row and column where the upper left corner of the data lies in the file.
Defining R and C is useful when you want to extract only the data of your interest.
