May 7th, 2024, 6:49pm
PFD reset path mismatch (Read 9000 times)
neoflash
Mixed-Signal
Designer
Oct 05th, 2006, 11:18am
Hi:
For bang-bang PFD, what will happen if up/dn reset path is not symetrical?
anything more than a static phase offset?
Re: PFD reset path mismatch
Reply #1 - Oct 11th, 2006, 10:51pm
Statice phase error will be the big one I beleive.
A lot of PFD are donw with timing that you get a small PU and a small PD when the device is in "perfect phase" this minimizes the so-called deadbanding and miismatch problems when these pulses decrease to zero time periods.
vivkr
Reply #2 - Oct 20th, 2006, 5:31am
Maybe I am wildly off the mark but I can see another subtle effect if the
UP/DN paths are not symmetrical:
limit cycles in the VCO frequency may arise because of the following effect:
1. As the phase error goes close to zero, there is a net charge delivered to the loop filter which
would not happen if the UP/DN pulses were symmetrical. Firstly, this will cause static phase error.
2. Secondly, depending on the dynamics of your loop, you may be pushing your PLL out of its stable
range. To see this, consider that the gain of the PFD increases for phase errors close to zero as the
amount of charge dumped onto the loop filter does not scale down linearly with the phase error, and
tends to be higher than what you would get from a linear scaling. Thus, the gain of the path is different
from the gain assumed when doing stability analysis. Thus, the loop is pushed away from its stable
point as it closes in onto the zero phase error point.
3. Since the loop returns to its normal stable state as soon as the phase error is a little larger, the stability
is restored, and you get limit cycles and not a full-blown oscillation, which result in frequency modulation of the VCO frequency. I expect that
the effect should be quite small though. Besides, this will only happen if the loop is unstable for the increased PFD gain.
Comments are invited from PLL experts !!!
Vivek
Reply #3 - Oct 22nd, 2006, 8:15pm
Hi Vivek,
I designed several PLLs, all with PFDs without dead-zone. That is conventional PFD design, which makes UP/DN almost symmetry and linear to the phase error. However, it always has a little amount of charge delivered to the loop filter. I know that is due to UP/DN current mismatch. So sometimes I think the VCO gain should be small if I want to design a low-jitter PLL. Am I right?
The PLLs I designed are all programmable and with wide VCO range, high VCO gain. I have been troubled by the large jitter. Period jitter is rms 15ps - 20ps.
Best regards,
Yawei
vivkr
Reply #4 - Oct 22nd, 2006, 11:45pm
Hi Yawei,
I am no PLL expert as mentioned above Smiley Besides, I was talking of PFD+CP gain.
However, I would say yes, the VCO gain should be as low as possible (while meeting required
range and other specs) to reduce jitter from it. Intuitively, it would seem that for a given
VCO frequency, the lower the gain, the less sensitive it would be to noise on its input.
Besides, the period jitter you mention is useful only if you also specify the VCO frequency.
Maybe, then someone (a PLL expert) can suggest a solution to your jitter problem. I don't
think that a small UP/DN current mismatch would cause you big problems, but I maybe wrong.
Vivek
ywguo wrote on Oct 22nd, 2006, 8:15pm:
Hi Vivek,
Best regards,
Yawei
David Lee
Reply #5 - Oct 23rd, 2006, 12:46am
Hi Vivek,
Best regards,
Yawei
Reducing UP/DN current mismatch can sometimes help. Are you observing a large static phase offset? Reducing VCO gain and period jitter, noise in charge pump as well as loop filter can help. Cause of excessive PLL jitter can be due to any one of PFD/CP, LF, VCO, etc. Why so sure the cause is charge pump current mismatch?
- David
Reply #6 - Oct 24th, 2006, 7:12pm
Hi David,
I thought of UP/DN current mismatch because they were always unequal in SPICE simulation. So it induced very small ripple of the control voltage of VCO.
You are correct. Any noise in PFD, CP, LPF, and VCO causes jitter. However, there must be a large static phase error due to UP/DN current mistmatch. I will try to measure the phase error in next design. Smiley
BG
Yawei
Reply #7 - Nov 13th, 2006, 9:53am
Jitter in a PLL can come from a bunch of different sources, and they all need to be considered:
A partial list that I can think of off the top of my head (and some suggested fixes)
Ground noise coupling into the delay cell. (keep it differential and a current source at the bottom to isolate the delay element)
Power noise coupling into the delay cell.
(put an internal voltage regulator over the ring oscillator to keep this quiet)
Noise coupling into the VCO control line (filter inside the chip, not outside)
Noise coupling between stages of the delay cells in the VCO (layout with good attention to grounding and substrate contacts, and localized HF filtering very close to each cell)
Noise coupling between delay cells thought the VCO control line (localized filter to remove this transition path)
Imbalance of capacitive paths between delay cells. (fix the layout)
Transitioning the delay cell before it has an opportunity to settle out fully again. (Architect to allow the cell to sit stable for a while before transitioning again)
Slew rate of the delay cell transitions being a long slope (edge to edge jitter is a product of two things, noise on the signal and the slope of the signal as it transistions.)
Charge injection in the charge pump structure (use an balanced H-bridge current steering architiecture, compensation for charge injection and the follower op-amp to stransition the current steering switches to similar voltage to what goes into the charge pump.)
And the list goes on and on and on.....
I need to write a book!
Grin
Jerry
Reply #8 - Nov 13th, 2006, 9:28pm
Hi Jerry,
A very good list.
I agree on the above point. I always use on-chip cap of several hundreds of pico-farads for those clock synthesis PLLs. However, some high performance PLLs for RF application have external caps when it needs a very huge cap. Does it have noise coupling issues?
Yawei
Reply #9 - Nov 27th, 2006, 12:38pm
Quote:
A very good list.
Thanks, the product of "lots of learning experiences" so to speak.
Yes it is an issue if it is in a mixed signal environment. In an RF design, if it is on the leadframe in any form it will talk into the LNA front end and into the VCO.
One of the reasons that a lot of RF front ends still exist on stand alone chips.
Jerry
