Aug 15th, 2024, 5:32pm
LO-RF isolation (Read 3160 times)
sivacha
India
LO-RF isolation
Oct 18th, 2006, 9:58pm
how to simulate for the LO-RF isolation for a mixer using spectreRF??
ACWWong
Oxford, UK
Re: LO-RF isolation
Reply #1 - Oct 19th, 2006, 6:48am
You can simulate using pss+pxf. check out the cadence documentation in you intstallation path for details.
You can also do a simpler/quicker sp analysis for get a idea of the LO to RF feedthru.
Please bear in mind though, an ideal schematic simulation often will give an unrealistic performance of LO to RF leakage because effects which dominate this (for espically differential circuits) are layout and mismatch. So post extraction simulation in addition to monte-carlo is needed to get a realistic figure.
Also see the mixer testbench pdf under analysis on this website.
cheers
aw
