May 17th, 2024, 12:36pm
Simulator cannot determine necessary timestep (Read 2944 times)
Pavel
Lausanne/Switzerland
Oct 25th, 2006, 3:51am
Hello
Is there any option that could make the Spectre simulator "more intelligent" in timestep choice.
When I display excursion of V(out) on some seconds simulation time
parameter real FREQ = 13.56M;
parameter real AMPL = 1;
analog V(out) <+ AMPL*sin(`M_TWO_PI*FREQ*$abstime);
I see horisontal line.
Is defining the value of Maxstep in Simulator settings only choice for credible simulations.
Thanks in advance.
Pavel.
Daniel_Platte
Munich/Germany
Re: Simulator cannot determine necessary timestep
Reply #1 - Oct 25th, 2006, 5:07am
$bound_step might solve your problem "smarter" than limiting maxstep. See Verilog-AMS LRM 2.2 section 10.8 for example.
Daniel
Pavel
Reply #2 - Oct 27th, 2006, 1:31am
Ok, Thanks.
