May 9th, 2024, 9:32pm
"Charge" and  "Flux" natures - theirs usefuln (Read 4982 times)
Pavel
Lausanne/Switzerland
Nov 10th, 2006, 5:01am
Hello
1. I don't understand how one can exploit Charge and Flux natures in disciplines.vams.
I tried to find examples on Internet targeting access functions 'Q' and 'Phi', but I failed.
There are examples where people emulate charges, but charges are declared as real variables .
Taking derivatives from these 'real variable' charges they calculate current. So what is usefulness of Charge and Flux natures declared in disciplines.vams.
In my case I want to simulate reception of magnetic flow on RFID tag. How to proceed - just apply signal on tag borns and ignore existance of inductor? Or there is more "smart" approach?
2. Trying to simulate underlying code I have fatal initialization error.
module L_FLUX_test;
electrical A, B, gnd;
ground gnd;
parameter real FREQ = 100;
parameter real AMPL = 10;
real flux;
inductor #(.l(50u)) L1 (A,B);
resistor #(.r(1k)) R1 (A, gnd);
resistor #(.r(1k)) R2 (B, gnd);
analog begin
     @ (initial_step) flux = 0;
     flux = AMPL*sin(`M_TWO_PI*FREQ*$abstime);
     V(A, B) <+ ddt(flux);
     $bound_step(0.05/FREQ);
Fatal error found by spectre during topology check.
   The following branches form a loop of rigid branches (shorts) when added to
       the circuit:
       L_FLUX_test:A_B_flow (from L_FLUX_test.A to L_FLUX_test.B)
spectre terminated prematurely due to fatal error.
ncsim: *E,RNAERR: Simulation is complete, analog initialization error.
Pavel.
Re: "Charge" and  "Flux" natures - theirs use
Reply #1 - Nov 10th, 2006, 5:30am
Pavel -
You have two things across (A,B) that are both trying to set the voltage:
and
At time=0, both are shorts (V=0), and you can't put two 0-volt voltage sources in parallel (physically, any arbitrary current can flow in the loop created by the two of them; mathematically, you have a singular matrix).
I generally work with the electrical discipline, that is, with voltage and current, rather than with flux and charge.  I suppose you could define a flux source and a module that had a flux input and converted it to a voltage.
module flux_source(out);
  inout out;
  magnetic out;
  analog begin
    Phi(out) <+ AMPL*sin(`M_TWO_PI*FREQ*$abstime);
module flux_recv(in, vout);
  inout in, vout;
  magnetic in;
  electrical vout;
  analog
    V(vout) <+ ddt(Phi(in));
Pavel
Re: "Charge" and  "Flux" natures - theirs usefuln
Reply #2 - Nov 10th, 2006, 6:50am
Thank you Geoffrey,
Your response confirms my original opinion concerning Charge and Flux natures.
They are USELESS.
Supposing that one knows Charge (or Flux) functions: CHARGE = F1(time), FLUX = F2(time).
Current through capaitor and voltage on inductor could be assigned ignoring physical nature of charge (flux).
One can declare CHARGE and FLUX as real variables - it will be sufficient. Then apply to them ddt function and we have current and voltage...
electrical A,B,C,D;
real CHARGE, FLUX;
analog begin
  CHARGE = sin(`M_TWO_PI*FREQ*$abstime);
  FLUX = sin(`M_TWO_PI*FREQ*$abstime);
  I(A, B) <+ ddt(CHARGE);
  V(C,D) <+ ddt(FLUX);
Or I miss something ...
Concerning your verilog-A code - the inductor isn't mentionned.
How can I modelize the reception of a RF-signal by LC-tank.
Regards.
Pavel.
Reply #3 - Nov 13th, 2006, 3:12am
Pavel wrote on Nov 10th, 2006, 6:50am:
They are USELESS.
You did miss something.  The creation of different natures allows you to set different tolerances on the variables: if the simulator applied ABSTOL (which usually runs around 1e-12 in Spice-like simulators) to charge variables (which in modern MOSFETs runs in the 1e-18 range, then you could never expect the charge to give accurate results, because any answer would be below the tolerance.
Also, there's some mention about compatible disciplines -- a good simulator will warn you (or give an error) if you accidentally connect a magnetic port to one that is really supposed to be electrical.  I heard a story once about a designer who accidentally connected the "thermal terminal" of a bipolar model with self-heating to an electrical wire in a Spice simulator; he thought Kirchoff's current law was being violated because current was disappearing into the "thermal ground" of the BJT model (and he must have been getting the wrong answer because his BJT was incorrectly computing its temperature).
I think you'd need to write your own inductor with the usual two electrical ports and a magnetic port to bring in the RF:
module fluc_recv(a,b,rf_in);
  inout a, b, rf_in;
  electrical a, b;
  magnetic rf_in;
  parameter real L = 1n from (0:inf);
  analog
    V(a,b) <+ ddt(L * I(a,b) + Phi(rf_in));
Pavel
Reply #4 - Nov 15th, 2006, 12:07am
Thanks Geoffrey
I tested your suggestion. Indeed RF field declared as real doesn't work.
module L_FLUX_test;
electrical A, B, C, D, emf, emf_real, gnd;
magnetic flux;
ground gnd;
parameter real FREQ_RES = 13.56M;
parameter real FREQ = FREQ_RES*2;
parameter real AMPL = 1u;
parameter real Cc = 10p;
parameter real Lc = 1/pow(`M_TWO_PI*FREQ_RES,2)/Cc;
parameter real Rlkg = 1G;
real flux_real;
resistor #(.r(1k)) R3 (C, gnd);
resistor #(.r(1k)) R4 (D, gnd);
analog begin
     Phi(flux) <+ AMPL*sin(`M_TWO_PI*FREQ*$abstime);
     V(emf) <+ -ddt(Phi(flux));
     I(A,B) <+ V(A,B)/Rlkg + Cc*ddt(V(A,B)) + 1/Lc*idt(V(A,B)+V(emf));
     flux_real = AMPL*sin(`M_TWO_PI*FREQ*$abstime);
     V(emf_real) <+ -ddt(flux_real);
     I(C,D) <+ V(C,D)/Rlkg + Cc*ddt(V(C,D)) + 1/Lc*idt(V(C,D)+V(emf_real));
You could see the simulation results in attachment picture.
Best Regards
Pavel.
Reply #5 - Nov 16th, 2006, 11:33am
The LRM says that idt() without an initial condition has to be used in a feedback loop that forces its inputs to zero.  I would suggest you look into that, or convert to ddt() as I used in my module.
