hchanda
Geoffrey thank you for the answer.
Ken, I'll take care to follow your suggestion. I completely agree with you. The model is
// Based on the OVI Verilog-A Language Reference Manual, version 1.0 1996 // //
`define PI 3.14159265358979323846264338327950288419716939937511
//-------------------- // opamp // // - operational amplifier // // vin_p,vin_n: differential input voltage [V,A] // vout: output voltage [V,A] // vref: reference voltage [V,A] // vspply_p: positive supply voltage [V,A] // vspply_n: negative supply voltage [V,A] // // INSTANCE parameters // gain = gain [] // freq_unitygain = unity gain frequency [Hz] // rin = input resistance [Ohms] // vin_offset = input offset voltage referred to negative [V] // ibias = input current [A] // iin_max = maximum current [A] // slew_rate = slew rate [A/F] // rout = output resistance [Ohms] // vsoft = soft output limiting value [V] // // MODEL parameters // {none} //
module opamp(vout, vref, vin_p, vin_n, vspply_p, vspply_n); input vref, vspply_p, vspply_n; inout vout, vin_p, vin_n; electrical vout, vref, vin_p, vin_n, vspply_p, vspply_n; parameter real gain = 835e3; parameter real freq_unitygain = 1.0e6; parameter real rin = 1e6; parameter real vin_offset = 0.0; parameter real ibias = 0.0; parameter real iin_max = 100e-6; parameter real slew_rate = 0.5e6; parameter real rout = 80; parameter real vsoft = 0.5; real c1; real gm_nom; real r1; real vmax_in; real vin_val;
electrical cout;
analog begin
@ ( initial_step or initial_step("dc") ) begin c1 = iin_max/(slew_rate); gm_nom = 2 * `PI * freq_unitygain * c1; r1 = gain/gm_nom; vmax_in = iin_max/gm_nom; end
vin_val = V(vin_p,vin_n) + vin_offset;
// // Input stage. // I(vin_p, vin_n) <+ (V(vin_p, vin_n) + vin_offset)/ rin; I(vref, vin_p) <+ ibias; I(vref, vin_n) <+ ibias;
// // GM stage with slewing // I(vref, cout) <+ V(vref, cout)/100e6;
if (vin_val > vmax_in) I(vref, cout) <+ iin_max; else if (vin_val < -vmax_in) I(vref, cout) <+ -iin_max; else I(vref, cout) <+ gm_nom*vin_val ;
// // Dominant Pole. // I(cout, vref) <+ ddt(c1*V(cout, vref)); I(cout, vref) <+ V(cout, vref)/r1;
// // Output Stage. // I(vref, vout) <+ V(cout, vref)/rout; I(vout, vref) <+ V(vout, vref)/rout;
// // Soft Output Limiting. // if (V(vout) > (V(vspply_p) - vsoft)) I(cout, vref) <+ gm_nom*(V(vout, vspply_p)+vsoft); else if (V(vout) < (V(vspply_n) + vsoft)) I(cout, vref) <+ gm_nom*(V(vout, vspply_n)-vsoft); end endmodule
