May 20th, 2024, 3:27pm
Nodeset for internal nodes in spectre (Read 3151 times)
biffovic
Munich, Germany
Dec 14th, 2006, 6:11am
HI!
I was trying to set initial guesses for a VerilogA modul in spectre. The manual said
nodeset Voff=0 X3.7=2.5 M1:int_d=3.5 L1:1=1u
where M1 is the name of a transistor and int_d is the internal drain node. However, this did work. Spectre warned me that it couldn't find this node.
Does anyone know how to set node voltages for internal nodes of devices, models or compiled models (cmi)?
Thanks a lot!
Chris
Re: Nodeset for internal nodes in spectre
Reply #1 - Dec 14th, 2006, 8:06am
That should work. Are you sure M1 has an internal drain?
