May 18th, 2024, 12:13am
SpectreRF PAC specialized analyses (Read 2932 times)
anis
France
Jan 18th, 2007, 1:50am
Hi everybody,
I'm running PSS+PAC analyses to get the transfer function of an RF subsampling Rx chain based on switched capacitors.
I'm using the SpectreRF version included with mmsim6.0.
In the "specialized analyses" field of the PAC menu, there is a special analysis named "sampled" which is not mentioned in the SpectreRF manual.
What is this option for ? and how could someone set it to work efficiently ?
I was  wondering if this special analysis could  help me, because t he PAC results I'm having at the moment (without any special analyses) are not 100% correct (presence of extra notches due to several decimations throughout the Rx chain).
Thanks in advance,
Anis.
Re: SpectreRF PAC specialized analyses
Reply #1 - Jan 22nd, 2007, 4:08am
The purpose of this analysis is to allow you to add an ideal strobe on the analysis, generally at a crossing threshold. As a consequence, you can get the gain (or rather small-signal signal level) at that point in the period, rather than the time-averaged signal level.
It's analagous to the time domain or jitter modes of pnoise analysis, but for pac (you can do this with pxf too).
