May 18th, 2024, 12:44am
stability analysis for time Varying Ckt. (Read 4713 times)
choudhar
Feb 13th, 2007, 12:39pm
I have  a mixer circuit around which I am trying to fold a common-mode feedback circuit. Classical stability analysis does not work now as they are ac analysis around dc operating point points. Hence I need to do a stability analysis around a PSS operating point instead. Apparently there is an analysis method called PSTB (periodical Stability ) analysis in Cadence , but I do not have that version presently. However I think all what I need to do is somehow make stability analysis pick the operating point information from the pss analysis.
Does anyone know..how to do this. Or if anyone has a better idea to deal with this kind of situation...
Frank Wiedmann
Munich, Germany
Re: stability analysis for time Varying Ckt.
Reply #1 - Feb 13th, 2007, 11:38pm
You can emulate a pstb analysis by combining the results of two pac analyses. This will require some work for setting up the simulations and equations, however. See http://www.designers-guide.org/Forum/?board=power-electronics;action=display;num... for details.
choudhar
Reply #2 - Feb 14th, 2007, 12:43pm
Thanks Frank.
The discussion was very helpful, however a left me wanting more. For the time being , can you please tell me that if I implement Middlebrook's method of stb analysis , however instead of ac analysis I do pac .., it is the same PSTB analysis. Once I have PSTB analysis with me , I can probably answer that myself, however in the meantime if you have  a readymade answer.
Also are there implementation notes on PSTB analysis just as there is one STB analysis. In the same vein, are there more details on state-space averaged model for stability analysis.
Frank Wiedmann
Munich, Germany
Reply #3 - Feb 14th, 2007, 11:44pm
Like you said, a pstb analysis is the same as an stb analysis, just using pac instead of ac. You can either take the article mentioned in reply #48 as a guide or my implementation in LTspice mentioned in reply #16. If you follow the LTspice implementation, you might also want to take a look at the thread starting with message 2482 in the Yahoo group, which contains some explanations about the circuit.
With pac, you additionaly need to make sure that you are using the correct sideband. I would recommend you to use a node in your loop where you have a continuous signal and use sideband 0. The pstb analysis of SpectreRF is also using sideband 0.
What is generally known as Middlebrook's method is not the same as stb analysis because Middlebrook's method was developed for a circuit with no backward transmission whereas stb analysis takes both forward and backward transmission into account so that the orientation of the probe does not matter. Regarding Middlebrook's more recent method, please see my comment at http://www.designers-guide.org/Forum/YaBB.pl?num=1155668476/17#17.
