Oct 5th, 2024, 11:30pm
biasing current (Read 2817 times)
aaron_do
biasing current
Mar 12th, 2007, 2:24am
I've found that the resistor variation from the model to the fabricated one can be enormous. For a biasing circuit like a bandgap reference, resistors are quite necessary (although I've seen some resistorless designs). This causes the results to be very different from expected. What kind of techniques do people use to get around that? Also, what is a good CMOS bandgap for 1.8 V supply?
thanks,
Aaron
monte78
Re: biasing current
Reply #1 - Mar 12th, 2007, 2:35am
The point is that you cannot obtain an accurate value of resistors, but you can obtain an accurate matching of resistors. Usually you design a bandgape reference where your voltage reference depends on the ratio of resistors and on base-emitter voltages. You can search here for some ideas:
http://www.circuitsage.com/bandgap.html
aaron_do wrote on Mar 12th, 2007, 2:24am:
thanks,
Aaron
Venkateshr
Bangalore
Re: biasing current
Reply #2 - Mar 12th, 2007, 5:47am
For the Voltage BG ref the question is over matching of resistors and not individual resistor tolerance.but for Iref it is Vbg/R like ckt which depends on R inversely and in first order itself.Here we should see to the variations of resistor with process (also with temp but this can be compensated)    :'(
aaron_do
Re: biasing current
Reply #3 - Mar 12th, 2007, 8:53am
thanks for the replies.
As Venkateshr pointed out the current produced by the current mirrors in the BG circuit is sensitive to resistor variation. I did find a paper which seems to have a solution to this problem though...
"A new low voltage precision CMOS current reference with no external components"
it can be found from IEEE xplore
cheers,
Aaron
