Jun 30th, 2024, 1:46pm
Lag-Lead Filter Design (Read 4166 times)
elec_eng
Mar 16th, 2007, 6:59am
Hi.
I need to use a lag-lead filter. The configuration of this filter can be seen on the attachment.
It will be used on a PLL cirucit with chip LM565. The data sheet can be found at:  http://www.national.com/ds/LM/LM565.pdf
I need to work out the values for C1, C2 and R2 if the cut off frequency is 1kHz.
What equations can i use?
OR
What would the values for C1, C2 and R2 need to be?
Please help. Thanks.
