This seems reasonable behaviour to me.
If you only want to use an integer for single bit operation, you can always and the results with 1:
(a~^b)&1
which will give what you're expecting.
In Verilog-AMS you can use logic signals, and so define the bit length of the word you want. But in Verilog-A, you just have integers.
