Aug 15th, 2024, 1:14am
Strange XNOR behavior in veriloga using spectre (Read 2631 times)
naone
San Diego
Apr 13th, 2007, 9:25am
I am using veriloga in spectre.  When I use the xnor built in function of ^~ or ~^ I get funny results.
integer a,b
a=1;
b=1;
c=a~^b;
c evaluates to -1
integer a,b;
a=0;
b=1;
c=a~^b;
c evaluates to -2
I think what is going on is all the integers are represented as a multi-bit integer and the ~^ is going the operation bit-wise.  The resulting number is then a negative number in 2s complement.  Is there a way to implement a and b as a binary value?
BTW c=!(a^b) works for me now but I would like to understand this a little better.
Naone
Re: Strange XNOR behavior in veriloga using spectr
Reply #1 - Apr 16th, 2007, 3:53am
This seems reasonable behaviour to me.
If you only want to use an integer for single bit operation, you can always and the results with 1:
(a~^b)&1
which will give what you're expecting.
In Verilog-AMS you can use logic signals, and so define the bit length of the word you want. But in Verilog-A, you just have integers.
