May 18th, 2024, 8:18am
*Error* eval: undefined function - schHiViewToView (Read 4461 times)
rajdeep
UK
Apr 17th, 2007, 9:09am
I could run the  following SKILL command through the OCEAN interface.
schViewToView( "srcLib" "srcDesign" "myLib" "myDesign" "symbol" "functional" "schSymbolToPinList" "schPinListToVerilog"
The error message was:
What could be the reasons?
However, this command worked when I typed this in the CIW (Command Interpreter Window). Is OCEAN the right interface I'm using?
Rajdeep
« Last Edit: Apr 18th, 2007, 5:06am by rajdeep »
Re: *Error* eval: undefined function - schHiViewTo
Reply #1 - Apr 19th, 2007, 3:34am
Doing this from the ocean executable does not make sense, since it does not have the code to do schematic and symbol editing and modification (i.e. the "sch" functions).
The ocean executable is for doing simulations, and post-processing the results.
