John O Donovan
San Jose, CA
If you are using BSIM4 or BSIM3v3 models, then there are instance parameters for doing this in Spectre. You can use
delvto shift in zer0-bias threshold voltage vth0. delk1 shift in body bias coefficient k1. delnfct shift in subthreshold swing factor nfactor.
You can find descriptions in 'spectre -h'
Regards, John
