May 5th, 2024, 1:42am
mismatch analysis (Read 5463 times)
Pravinkumar
Bangalore
mismatch analysis
May 01st, 2007, 11:57pm
Am trying to find mismatch in current mirrors through DC analysis. I try to measure the current output by varying the three parameters w, l and vtho of the key transistorsm in the current mirror. I am able to sweep the two component parametrs w and l. Since vtho is a model parameter am not able to introduce mismatch to it.
Is there any way to declare it as a variable so that i can use it as another sweep parameter? Is it like the pdk should support the variations of the vtho? any suggestions??????
Am using spectre simulator.
Thanks in advance.
PS: No model files available to run monte Carlo or dcmatch analysis.
ACWWong
Oxford, UK
Re: mismatch analysis
Reply #1 - May 2nd, 2007, 8:04am
A simple (but crude) method would be to introduce a voltage source in the gate of the transistor to sweep the impact of vgs mismatch, which is correlated to threshold mismatch.
John O Donovan
San Jose, CA
Reply #2 - May 2nd, 2007, 9:34am
If you are using BSIM4 or BSIM3v3 models, then there are instance parameters for doing this in Spectre. You can use
  delvto   shift in zer0-bias threshold voltage vth0.
 delk1    shift in body bias coefficient k1.
 delnfct  shift in subthreshold swing factor nfactor.
You can find descriptions in 'spectre -h'
 John
Reply #3 - May 8th, 2007, 1:41pm
There's also spectre's dcmatch analysis (see spectre -h dcmatch for more details). There are parameters in bsim4 and bsim3v3 (and some other models too), for example:
DC-mismatch dependent parameters:
816     mvtwl=0.0 V*m     Threshold mismatch area dependence.
817     mvtwl2=0.0 V*m^1.5
				  Threshold mismatch area square dependence.
818     mvt0=0.0 V	  Threshold mismatch intercept.
819     mbewl=0.0 m	 Beta mismatch area dependence.
820     mbe0=0.0	    Beta mismatch intercept.
