Aug 16th, 2024, 12:38am
jitter from phase noise (Read 4320 times)
sivacharan
May 08th, 2007, 7:46pm
Hi
I would like to know how we can derive the value of the jitter from phase noise curve.
I am attaching a paper(softlink) which describes this. But iam confused how the author found the area.
He is calculating the area in the range 12K to 10MHz. But if we see the phase noise range, it is in the order of -110dBc/Hz. The area under the curve between the freq ranges is -63dBc.  How this can be possible?
http://assets.zarlink.com/CA/Phase_Noise_and_Jitter_Article.pdf
Can any one explain the calculation behind this?
Thanks.
imtired
Santa Rosa
Re: jitter from phase noise
Reply #1 - Jun 5th, 2007, 3:17pm
The paper doesn't give the function for the phase noise curve, but by eyeing the graph, this is what I calculated:
Assuming L(f) = k + a/f in the region of integration, (where a,k are constants, and f is frequency)
integral( k+a/f, from f1 to f2 ) = k*(f2 - f1) + a* ln( f2/f1 ), where k=10^-150/10, and a = 10^-140/10 * 12e3, f1=12e3, f2=20e6.
plugging in and convert to dBc:
10 * log( 1e-15*(20e6-12e3) + 1e-14*12e3*ln(20e6/12e3) ) ~ -76.8 dBc.
My answer is not the same as in the paper, but I think it's pretty close, given that I had to eyeball the function.
But this should demonstrate how to go about integrating the area under a phase noise curve, as a step to calculating the jitter.
Notice that L(f) has units dBc/Hz.  Once you integrate over frequency, you get [dBc/Hz] * [Hz] = dBc.
I hope this helps you.
Robert
buckaroo
Tsinghua Univ. PRC
Reply #2 - Oct 23rd, 2007, 9:41pm
as a rule of thumb, you can convert phase noise to jitter by the equation:
jitter^2=(fm^2/fo^3).L(f)
for example: 15ps, fo=21.88MHz
then @1MHz pnoise=-116.3dBc/Hz
which is 15p^2=(1M^2/21.88M^3)*10^-11.63
be careful, it won't be accurate at low frequency for its 30dBc/dec, not 20dBc/dec slope
sivacharan wrote on May 8th, 2007, 7:46pm:
Hi
Thanks.
imtired
Santa Rosa
Reply #3 - Nov 15th, 2007, 11:06am
Buckaroo, your equation for computing jitter from a single phase noise offset seems highly limited to some very specific situation, whatever that may be.  I would advise against making such a blanket statement on using this equation as a rule of thumb for calculating phase noise, especially for more complex phase noise curves such as found in systems with cascaded PLLs.
