didac
![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif) ![* *](https://designers-guide.org/forum/Templates/Forum/default/stargold.gif)
![](https://designers-guide.org/forum/avatars/blank.gif)
There's a million ways to see the things in life
manresa,spain
Hi, R per unit length can be found in your foundry documentation. C's depends on how its drawn the layout so its difficult to give you an estimation. One method I used is to drawn a couple of parallel tracks on the same metal and different combination of metals(5 and 4,6 and 5 and so on...) and do a parasitic extraction so I can get a magnitude order(I usually put them at minimum distance as a worst case). Good luck with your design.
