Aug 17th, 2024, 9:18pm
Deep N-well layout (Read 1095 times)
sandman
Deep N-well layout
Jun 05th, 2007, 12:45pm
Would anyone know how the deep n-well is connected in the layout for capacitors and MOSFETs ? Does it have to be connected to any of the supplies Vdd/Gnd ? Is it tied to the bulk ? Is it left floating ? During a DRC, I end up with a psubStampError and have a feeling it is because I've left the deep N-well floating.
I'm designing this for an RF IC.
Any help is appreciated. Thanks, in advance. Cheers.
ACWWong
Oxford, UK
Re: Deep N-well layout
Reply #1 - Jun 5th, 2007, 2:09pm
It should be connected as depicted in the schematic. Most FETs or MOScaps modern design kits will either have an explicit connection for the deep N-well, or an inherited net.
If its not part of the schematic, its better to tie to VDD. That way the Nwell to psub diode is at maximum reverse bias and so minimum capacitance.
sandman
Reply #2 - Jun 6th, 2007, 4:35am
Thanks for that, ACWWong
I am using the TSMC 0.18. The schematic doesn't seem to show any explicit connections for the d-nwell. I was of the same opinion (that I should connect it to VDD to minimise the diode cap.), but was wondering that it would complicate the layout with the additional connection to VDD. That would make an already compact layout pretty crowded !
Have you had a similar experience with TSMC 0.18, D-Nwell ?
krishnap
Reply #3 - Jun 6th, 2007, 7:13am
Typically Nwell of dNwell device would be connected to VDD.
Also there would be DRC rule for  spacing between Deep nwells,  which
will make the area larger, compared to using normal devices.
Krishna
sandman
Reply #4 - Jun 8th, 2007, 6:37am
Thanks for all your replies !
