Apr 26th, 2024, 5:34am
PLL transfer function (Read 3475 times)
sivacharan
Jun 16th, 2007, 2:38am
Hi
Can anyone explain how we can plot PLL transfer function(Output phase/ Input phase) using spectre and spectreRF?
If there are any documents pls share.
siva.
Jess Chen
California Bay Area
Re: PLL transfer function
Reply #1 - Jul 3rd, 2007, 8:48am
The answer depends on how you plan to model the PLL. If you are using a phase domain model, you can generate and plot the transfer functions with Spectre. If you are using a voltage domain model, you may want to try SpectreRF of some other RF simulator. You could also try to simulate an impulse response and then take the Fourier transform to get the transfer function but that would be very tricky.
How do you plan to model the PLL?
