Jul 16th, 2024, 12:37pm
VCO glitches in Verilog-A (Hspice) (Read 2594 times)
imtired
Santa Rosa
Jun 20th, 2007, 12:08pm
Using the VCO behavioral model from this website (with jitter), once in a while the VCO output level exceeds +/-1.  Simulating within a PLL, the longer I simulate, the greater the excursion.  Also, I am setting the jitter to zero, so it actually doesn't have any jitter being applied.
Has anyone previously observed such behavior?  Any hints, suggestions, insight as to what might be going on, and steps to resolving it?
Any help would be appreciated.
Robert
Re: VCO glitches in Verilog-A (Hspice)
Reply #1 - Jun 21st, 2007, 10:32am
The output voltage of the vco exceeds vh??
In vco2, I see:
  V(out) <+ transition(n ? vh : vl, 0, tt);
so it seems like it must be a simulator bug (in the transition function?) if the output voltage is ever outside the range (vl,vh), assuming vl < vh.
