May 18th, 2024, 4:50am
Accessing signal values during simulation (Read 4468 times)
rajdeep
UK
Jun 22nd, 2007, 1:26am
Is it possible to access voltage of a node, or current through a branch during simulation of a circuit using SpectreVerilog. I have heard about ocean interface, which allows post processing of simulated data. But is it possible to do the processing during the simulation.
Rajdeep
Unique
Russian Federation
Re: Accessing signal values during simulation
Reply #1 - Jul 4th, 2007, 6:12am
The only thing i could tell You, is that such a feature is now being realized in frames of CAD system AVOCAD, where You could see simulation resilts while You simulating (simulator AVOSpice+ postprocessor AVOProbe). Also  i know, that thos program package is relatively cheap.
Good luck!
Dina
View Profile Unique 200831583   IP Logged
haikom
Reply #2 - Aug 16th, 2007, 4:39am
what do you mean with accessing signals? It is possible to write a VerilogAMS model to monitor a current and e.g. write a error message to a log file.
Regards, haiko
View Profile haikomo   IP Logged
Reply #3 - Aug 17th, 2007, 10:36pm
Radjeep,
  Since you said that you wanted to process signals, here are
several ways to process signals while the simulation is running.
1) Add an element to the circuit to process the signal, for
   example, using a vcvs to create a differential signal from
   two single-ended signals
    for ADE users
2) Just use the ADE marching waveforms and do the processing
   in the waveform calculator. For example, when simulating
   a PLL, use the "freq" function to track whether the PLL locks
   or not.
   for Spectre RF-Simulink users
3) Use co-simulation and do the processing in Simulink
Reply #4 - Aug 18th, 2007, 4:16pm
Radjeep,
  One clarification, Spectre RF - Simulink co-simulation only supports
transient and envelope following analysis.
