Radjeep,
Since you said that you wanted to process signals, here are several ways to process signals while the simulation is running.
1) Add an element to the circuit to process the signal, for example, using a vcvs to create a differential signal from two single-ended signals
for ADE users 2) Just use the ADE marching waveforms and do the processing in the waveform calculator. For example, when simulating a PLL, use the "freq" function to track whether the PLL locks or not.
for Spectre RF-Simulink users 3) Use co-simulation and do the processing in Simulink
