Aug 15th, 2024, 3:57am
modelling nfet and pfet behavioural model verilogA (Read 335 times)
nishanis
Jul 18th, 2007, 3:07pm
I am trying to write a verilog-a behavioral model for pfet and nfet, i.e. using them as switches.
analog begin
     if (analysis("static")) begin
        Rch = Roff ;
     end else
     begin
        if (V(G) >=Vth) Rch = Ron ;
        else Rch = Roff ;
     end;
     I(S, D) <+ V(S, D) / transition(Rch,0,tr,tf);
The model works fine. But when i use both pfet and nfet models to build an inverter i just get 0 at output. I think i need voltage as output. SO i tried
V(S, D) <+ I(S, D) * transition(Rch,0,tr,tf);
But this gives segmentation fault in spectre.
Can anybody tell some changes in the model where i can model voltages?
Also, is there a standard model for nfet or pfet to operate them as switches which can be used to build logic gates.
Waiting for reply.
Smiley
Re: modelling nfet and pfet behavioural model veri
Reply #1 - Jul 18th, 2007, 7:33pm
Try mos0, a built-in primitive in Spectre.
Reply #2 - Jul 18th, 2007, 7:35pm
Alternatively, you can use the logic expression capability in Vlog-A to build true behavioral models of the gates.
Reply #3 - Jul 19th, 2007, 10:25am
nishanis wrote on Jul 18th, 2007, 3:07pm:
Segmentation fault?  Cool.  Are you running a current version of the simulator so you can open a support request?
When you used the curent formulation, did you remember to invert the sense of the gate voltage?  I'd also have used V(G,S) rather than just V(G).
nishanis
Reply #4 - Jul 20th, 2007, 10:38am
Hello Ken,
Thanks for replying.
Can you explain about the logic expression capability in Vlog-a. are you referring to model writer to get the behavioral model?
nishanis
Reply #5 - Jul 20th, 2007, 10:40am
Hello Geoffrey_Coram,
I tried your solution, its still giving the same segmentation fault.
I tried doing this also, but same error
analog begin
        Rch = Roff ;
     end else
     begin
        if (V(G,S) < Vth) Rch = Ron ;
        else Rch = Roff ;
     a = transition(Rch,0,tr,tf);
     V(S,D) <+ I(S,D) * a;
Hope to get further help from you.
thanks
Smiley
Reply #6 - Jul 20th, 2007, 12:56pm
Go to the Verilog-AMS page and download the basic inverter. This is the starting point. Add more inputs and calculate the output using simple logical expressions (&&, ||, !, etc.).
nishanis
Reply #7 - Jul 20th, 2007, 2:34pm
Hello ken,
I have done one set of simulation using those codes to which you are referring. But what i am trying to achieve is i have two models (pfet and nfet) so if anybody designs gates like, AOI222, or AO or any other, i wouldn't have to model another code. spectre would use those fet models and would act as switch and implement the functioning.
I got away with segmentation fault, using code below. But at output i am getting 1.8v straight line. its not switching when vth drops. Its always at 1.8v when i/p is at 1.8v and 0 v when i/p as it 0v.
analog begin
@(cross (V(control)- vth,  0,
           slack, control.potential.abstol))  begin
      if (V(control) >= vth )
              rout = roff;
      else
              rout = ron;
 a = transition(rout,0,100p,100p);
 V(vin,vout) <+ I(vin,vout) * a;
Reply #8 - Jul 25th, 2007, 9:31pm
Nishanis,
 In this case it might be easier to use the sw_no from the bmslib
to create the n-channel and p-channel device models. The model
formulation of the sw_no does not use the "if" function. This approach
works well for switching regulators[synchronous buck converters].
One point to consider is the on resistance of the switch, it needs
to be relatively high to minimize shoot-through current.
