Aug 15th, 2024, 4:44am
no-ideal amp compling errors (Read 3288 times)
westwind
Jul 19th, 2007, 11:30pm
         I'm using the non-ideal opamp model from AHDL library in Cadence. The code is the same as one posted by hchanda: http://www.designers-guide.org/Forum/YaBB.pl?num=1165362179/5#5.
        when I compling this code, It gives me some error like " ERR732 [73:7]: Input port 'vref' can only be probed."  I do not
understand this,  could anyone help me, thank you very much!
Frank Wiedmann
Munich, Germany
Re: no-ideal amp compling errors
Reply #1 - Jul 20th, 2007, 12:09am
A current is assigned to the vref port although it is only declared as an input port. Declaring it as an inout port will probably fix the problem. The compiler seems to have improved its checking, breaking old non-compliant code in the process.
westwind
Reply #2 - Jul 20th, 2007, 1:03am
It has been ok, thanks a lot!
