Aug 15th, 2024, 11:18am
Monte Carlo Analysis with QPSS (Read 219 times)
nxing
God help the person
who help themselves
China
Aug 06th, 2007, 12:08pm
Hi there,
I am running a Monte Carlo for QPSS analysis and
would like to measurement some non-linearity
characteristic of a mixer. The problem I am facing
is how to pick up a proper
harmonic that can be used as part of the
expression for Monte Carlo analysis. For example,
the frequency of (-1 1 0) and (-1 2 -1). I know I
can use function of "Harmonic" from special
function of calculator with PSS analysis. How to
set it up with QPSS?
Bill Toole
Re: Monte Carlo Analysis with QPSS
Reply #1 - Aug 8th, 2007, 5:17am
The syntax for qpss is quite similar to pss, the only main difference is you specify the mixing product for qpss not the harmonic number since there is no "harmonic" as there is in pss
Below is the syntax for the magnitude of the IF output voltage of a third order intermod product for a mixer with 2 tones at the RF
PSS   -> harmonic(v("/IFP" ?result "pss_fd") '(24))
QPSS -> harmonic(v("/IFP" ?result "qpss_fi") '((1 -2 1)))
Bill
nxing
God help the person
who help themselves
China
Reply #2 - Aug 8th, 2007, 1:17pm
Hi Bill,
Thanks for your reply. I actually tried this syntax before and the icfb reports that there are too many parameters for the function of harmonic.
Nxing
Bill Toole
Reply #3 - Aug 9th, 2007, 4:52am
Curious. I got the syntax from from using the Direct Plot Form and selecting the "Add To Outputs" button. You can then copy the expression from the "Setting Output" window into the calculator and it should work fine. I generally do this to make equations/expression that are not in the direct Plot Form and have had no problems unless I have changed the simulation in some way
Bill
Reply #4 - Aug 27th, 2007, 10:09pm
nxing,
Are you sure you got the parentheses in the right place? You might want to post the expression you used which gave the error about too many parameters?
nxing
God help the person
who help themselves
China
Reply #5 - Aug 28th, 2007, 5:21pm
Actually, it works now.
Thanks for the input.
