Matt VD
I would like to simulate a top-level digital testbench within Cadence ADE (that instantiates behavioural blocks for analog OR instantiates analog blocks).
When I open ADE, and try to select the config view for the behavioural view, I get the following error. *WARNING* dbOpenCellViewByType: Failed to open cellView (temp2 behavioral) from lib (my_lib) in 'r' mode because cellview does not exist. *Error* Could not open ( my_lib temp2 behavioral ) in "r" mode.
The only workaround that I know of is to create an empty symbol for the behavioral testbench, and then instantiate this in a schematic. However, this is not ideal.
Any suggestions? Am I missing something obvious? Or should this be a PCR?
