Jul 4th, 2024, 1:18pm
Q on Current Mirror from Razavi & Gray and Meyer (Read 2516 times)
nuky8181
Aug 22nd, 2007, 6:11am
Hi there,
Just started to pick up on knowledge on IC design and having problem understand the books. Hope someone can explain to a noob like me.
Q1) In Razavi book, pg 144, figure 5.13, it show a modification of a cascode mirror which is modified from a Cascode Mirror topology. could some one explain to me how it is being done? I have tried and come up with the following method. Is it correct?
Q2) From razavi book, left pic, it is the same circuit as the one in Gray and Meyer, on the right, right?
aaron_do
Re: Q on Current Mirror from Razavi & Gray and Mey
Reply #1 - Aug 24th, 2007, 8:07pm
i don't have the book handy but for Q1, the red line is not correct (I assume that's a connection?). Looks like the circuit on the right should replace the circuit in the blue dotted line...for Q2 yes you're right except M6 is assumed to be a current reference.
Aaron
dgsenthilkumar
India
Reply #2 - Sep 6th, 2007, 4:01am
Ya aaron_da is correct. For Q1, the right-side circuit is not equivalent of left circuit. The right-side circuit is equivalent to the circuit in the blue line.
View Profile dgsenthilkumar dgsenthilkumar 2876 Senthil Senthil   IP Logged
