Monkeybad
Basically I think this two method will get the same result, because it represent the loop-gain. The difference between method 1 and method 2 is that the method 2 its unit-gain BW seems faster. When you break the loop to measure the return ratio, you need to consider the output loading effect. In method 2, add some cap in the OP to slow down the unit agin BW maybe it will get the similar PM in method 1. This added cap is the output loading effect seen from the OP in returned signal. This just my thought to explain this phenomenon. I hope it help to find the correct reason.
BEST REGARD
