Nov 25th, 2026, 2:14am
VCO behavioral model (Read 3489 times)
Prathap
India
Oct 16th, 2007, 3:49am
I am currently working on modeling a VCO. I went through this piece of code from the Designer's Guide website.
module vco1 (out, in);
input in; voltage in;                        // input terminal
output out; voltage out;                  // output terminal
parameter real vmin=0;                        // input voltage that corresponds to minimum output frequency
parameter real vmax=vmin+1 from (vmin:inf);      // input voltage that corresponds to maximum output frequency
parameter real fmin=1 from (0:inf);            // minimum output frequency
parameter real fmax=2*fmin from (fmin:inf);      // maximum output frequency
parameter real vl=-1;                        // high output voltage
parameter real vh=1;                        // low output voltage
parameter real tt=0.01/fmax from (0:inf);      // output transition time
parameter real ttol=1u/fmax from (0:1/fmax);      // time tolerance
real freq, phase;
integer n;
analog begin
   // compute the freq from the input voltage
   freq = (V(in) - vmin)*(fmax - fmin) / (vmax - vmin) + fmin;
   // bound the frequency (this is optional)
   if (freq > fmax) freq = fmax;
   if (freq < fmin) freq = fmin;
   // bound the time step to assure no cycles are skipped
   $bound_step(0.6/freq);
   // phase is the integral of the freq modulo 2p
   phase = 2*`M_PI*idtmod(freq, 0.0, 1.0, -0.5);
   // identify the point where switching occurs
   @(cross(phase + `M_PI/2, +1, ttol) or cross(phase - `M_PI/2, +1, ttol))
     n = (phase >= -`M_PI/2) && (phase < `M_PI/2);
   // generate the output
   V(out) <+ transition(n ? vh : vl, 0, tt);
In this code i couldnt understand the cross statement used for identifying the point where the switching occurs. I mean i could understand the basic functionality of a sinusoidal VCO. But since this is a VCO whose output is a square wave i couldnt understand why the phase + `M_PI/2 is used to identify the switching. Moreover why is the phase limited from -PI/2 to PI/2. Is it the characteristic of the idtmod function?
Thanks.
Prathap
Re: VCO behavioral model
Reply #1 - Oct 16th, 2007, 11:11am
The last two arguments of the idtmod operator indicate that its output should range from -0.5 to -0.5+1.0=0.5. The return value is multiplied by 2π before it is assigned to the variable phase. Thus, phase is a sawtooth waveform that ranges from -π to π. The cross functions are set to trigger at -π/2 and π/2 to produce a square wave. You can produce a rectangular wave by changing those thresholds.
