Prathap
India
I am currently working on modeling a VCO. I went through this piece of code from the Designer's Guide website.
module vco1 (out, in);
input in; voltage in; // input terminal output out; voltage out; // output terminal parameter real vmin=0; // input voltage that corresponds to minimum output frequency parameter real vmax=vmin+1 from (vmin:inf); // input voltage that corresponds to maximum output frequency parameter real fmin=1 from (0:inf); // minimum output frequency parameter real fmax=2*fmin from (fmin:inf); // maximum output frequency parameter real vl=-1; // high output voltage parameter real vh=1; // low output voltage parameter real tt=0.01/fmax from (0:inf); // output transition time parameter real ttol=1u/fmax from (0:1/fmax); // time tolerance real freq, phase; integer n;
analog begin // compute the freq from the input voltage freq = (V(in) - vmin)*(fmax - fmin) / (vmax - vmin) + fmin;
// bound the frequency (this is optional) if (freq > fmax) freq = fmax; if (freq < fmin) freq = fmin;
// bound the time step to assure no cycles are skipped $bound_step(0.6/freq);
// phase is the integral of the freq modulo 2p phase = 2*`M_PI*idtmod(freq, 0.0, 1.0, -0.5);
// identify the point where switching occurs @(cross(phase + `M_PI/2, +1, ttol) or cross(phase - `M_PI/2, +1, ttol)) n = (phase >= -`M_PI/2) && (phase < `M_PI/2);
// generate the output V(out) <+ transition(n ? vh : vl, 0, tt); end endmodule
In this code i couldnt understand the cross statement used for identifying the point where the switching occurs. I mean i could understand the basic functionality of a sinusoidal VCO. But since this is a VCO whose output is a square wave i couldnt understand why the phase + `M_PI/2 is used to identify the switching. Moreover why is the phase limited from -PI/2 to PI/2. Is it the characteristic of the idtmod function?
Thanks.
