May 18th, 2024, 5:13am
Entering paramter through symbol interface (Read 2526 times)
rajdeep
UK
Dec 12th, 2007, 9:57am
In cadence virtuoso env it is possible to enter paramters through the symbol interface i.e. I instantiate
symbol of a module in a schematic and change its parameter by right clicking on the signal. A form opens
and then I change the parameters. This can be done if the module is a spectre or VerilogA view. But
not if it has a verilog view. I creates a mixed signal module by connecting a VerilogA module with a verilog module.
But the symbol of this combined block when instantiated in a schematic does not give any access to the parameters
used even in the verilogA module!!!!
Is there any work around?? Otherwise one has to go into the code and change the paramters manually!!
Rajdeep
rajdeep
UK
Re: Entering paramter through symbol interface
Reply #1 - Dec 18th, 2007, 8:32pm
Can anyone help me understanding what is this pPar thing.
I found it in http://www.tde.lth.se/home/jpr/myguide/Personal.html
This might be a way out!!
