Jul 16th, 2024, 12:52pm
modeling sdm using verilog-A (Read 5258 times)
min
Jan 08th, 2008, 9:36pm
Hi :
I have being modeling a 2nd DT sdm using verilog-A. I have model the diff-ota with verilog-A, and I use ideal switch in analogLib.
the diff-ota verilog-A model ac and tran simulation result is right.
but when I put these model in sdm , the simulator accuracy setting is conservative , when simulation the simulator will have convergence error, and I could't get the result.
when I change the simulator accuracy setting to moderate, the simulator will have no error, and I will get the result. but the result has more harmonics.
Is my diff-ota modeling has problem , or  modeling the switch cap filter has some special requirement to the ota verilog a modeling?
Min
Re: modeling sdm using verilog-A
Reply #1 - Jan 9th, 2008, 4:49am
Min,
  I have built second-order Sigma-Delta Modulators using Verilog-A. One suggestion
you might want to try is using the switch model in bmslib, sw_no. The transfer function
is smooth and continuous and has very good convergence. using it should allow you
to use the more accurate error preset.
Reply #2 - Jan 9th, 2008, 11:04am
Do you need to model the switch as a separate entity? I have had great success combining the amplifiers and switches into one behavioral model.
