Jul 18th, 2024, 1:25am
Analog transistors in deep-nwell (Read 22802 times)
Berti
Feb 07th, 2008, 12:10am
The technology I use offers deep (or buried) nwells. I am wondering whether the deep nwell will change the characteristics of the devices?
Because I assume that the transistor models haven't been measured for devices isolated by a deep-nwell(?) What difference can I expect
for transistors isolated by a deep nwell ... or can I neglect the influence.?.
Thanks for inputs!
Re: Analog transistors in deep-nwell
Reply #1 - Feb 7th, 2008, 6:30am
I don't know if there's any significant difference between a device in a (pwell in a) deep nwell versus one just in the p substrate.
However, I do know that there's a lot of work on the "well proximity effect", where the transistor is significantly altered if the *edge* of an nwell is close to it.  This is because the high-energy implant scatters off the blocking material (photoresist) and into the active area of the device.  You should be able to find more info by searching for WPE.
(Presumably, the high-energy implant passes through the active region of the device that's not near the edge, so the device won't be altered much.)
Berti
Reply #2 - Feb 7th, 2008, 10:32pm
Thank you Geoffrey for the input!
I also found a publication from Jiong-Guang Su et al. "Improving the RF Performance of 0.18um CMOS With Deep n-Well Implantation" published in IEEE Electronic Device Letters.
The authors provide measurements from a 0.18um technology and basically claim that DC characteristics aren't altered but Cgs can be reduced by up to 20% when using deep nwell.
vivkr
Reply #3 - Feb 8th, 2008, 12:19am
Hi Berti,
If the foundry offers devices in deep nwell, then it should normally also offer you models based on characterisation
of such devices. Depending on the foundry, there may be some/a lot of differences between these devices (isolated)
and standard nonisolated devices in a pwell process. Typically, I would expect that atleast the basic operation is
quite similar.
Which process is it by the way? Perhaps if someone else is using this process, they could tell you whether the models
are obtained from a characterisation of nwell devices or not.
Vivek
Berti wrote on Feb 7th, 2008, 12:10am:
Thanks for inputs!
Berti
Reply #4 - Feb 8th, 2008, 2:21am
I am using 130nm and 65nm processes from ST.
Does anybode have expierence from other processes where special "deep nwell models" are available?
HdrChopper
Reply #5 - Feb 25th, 2008, 4:54pm
Hi Berti,
I´m currently using a process with special deep nwell models. However - as Vivek pointed out correctly - basic operation is quite similar for the isolated and non-isolated devices. The differences mainly reside on the isolation junctions modeling, these junctions obviously not being present in the case of non-isolated devices. These might play a role when operating the device at high temperature (leakage currents) or might become important in case the device is, for example, connected to input/output interfaces that can be subjected to larger than normal operation voltages.
Finally, parasitics are certainly different and might also play a role in the device AC response, although this might only be important at relatively high frequencies.
Tosei
Keep it simple
Berti
Reply #6 - Feb 25th, 2008, 10:20pm
Hi Tosei,
The guys from the paper
claim that transistors in deep n-well have smaller cgs. However, they leave the buried nwell floating. Considering latch-up I am not sure if that is a good idea (also since the design-rules
prohibit that in the technology I am using).
Tosei, can you confirm the smaller parasitics (approx. 20%) when simulating the deep nwell models?
Terence
CAD Lab.
Taiwan, R.O.C.
Reply #7 - Jul 22nd, 2009, 2:24am
I am wondering if nMOS in floating DNW is not good for latch-up immunity.
Can anyone share the knowledge?
Thanks very much!
weber8722
Reply #8 - Nov 18th, 2011, 12:19am
Geoffrey_Coram wrote on Feb 7th, 2008, 6:30am:
I think beside isolation for reducing crosstalk there is one major difference!! With DNW you can bootstrap the bulk. This allows much better source followers with gain close to unity. With normal nmos the bulk effect reduces the gain a lot (like down to 0.9 Angry Angry). Also the shift in VTO vs Vbulk is not not and be be highly reduced with DNW Smiley.
Bye Stephan
Reply #9 - Nov 21st, 2011, 2:33pm
I helped define the deep n-well structures in the IBM SiGe processes.
They don't help that much with noise coupling.
Whats the issue?
Latch up and isolation? Its all about keeping things properly reverse biased and liberal use of contacts in the biasing.
