Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Apr 25
th
, 2024, 6:00pm
Home
Help
Search
Login
Register
PM to admin
Modeling
Passive Devices
› Setup material for N-well (in Standard CMOS Proces
Previous topic
Next topic
Setup material for N-well (in Standard CMOS Proces (Read 2890 times)
neoflash
Mixed-Signal
Designer
Feb 11
th
, 2008, 10:43pm
Hi, folks:
I've problem with setting up N-well material in HFSS. The relative permitivity and conductivity and other parameter setting in HFSS material manager sounds unfamalier with me.
Can people help on this?
Neo
IP Logged
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Setup material for N-well (in Standard CMOS Pr
Reply #1 -
Feb 12
th
, 2008, 1:13am
Hi neoflash,
You are using a EM simulator so you must look for magnetic/electric characteristics of the material. For example the two cuantities that you mention are defined as:
http://www.microwaves101.com/encyclopedia/permeability.cfm
http://www.microwaves101.com/encyclopedia/permittivity.cfm
Hope it helps,
IP Logged
neoflash
Mixed-Signal
Designer
Reply #2 -
Feb 12
th
, 2008, 5:42am
Thanks for the info. I think N-well is still silicon, thus I will use silicon's parameter for it.
IP Logged
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #3 -
Feb 12
th
, 2008, 9:50am
I agree with you to use data from silicon except for the conductivity, that I think that is doping dependant.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
»» Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
