Jul 2nd, 2025, 1:02pm
Setup material for N-well (in Standard CMOS Proces (Read 3654 times)
neoflash
Mixed-Signal
Designer
Feb 11th, 2008, 10:43pm
Hi, folks:
I've problem with setting up N-well material in HFSS. The relative permitivity and conductivity and other parameter setting in HFSS material manager sounds unfamalier with me.
Can people help on this?
Neo
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Setup material for N-well (in Standard CMOS Pr
Reply #1 - Feb 12th, 2008, 1:13am
Hi neoflash,
You are using a EM simulator so you must look for magnetic/electric characteristics of the material. For example the two cuantities that you mention are defined as:
http://www.microwaves101.com/encyclopedia/permeability.cfm
http://www.microwaves101.com/encyclopedia/permittivity.cfm
Hope it helps,
neoflash
Mixed-Signal
Designer
Reply #2 - Feb 12th, 2008, 5:42am
Thanks for the info. I think N-well is still silicon, thus I will use silicon's parameter for it.
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #3 - Feb 12th, 2008, 9:50am
I agree with you to use data from silicon except for the conductivity, that I think that is doping dependant.
