May 17th, 2024, 11:51am
MOS-capacitance of NMOS/PMOS (Read 8641 times)
Berti
Feb 19th, 2008, 7:57am
I recently simulated a MOS capacitor. This is shown in the Figure for NMOS and PMOS, when sweeping
the voltage over the capacitor. However, I observed that the maximum capacitance in inversion is different
for NMOS and PMOS (PMOS on the left side, NMOS on the right side of the plot).
To me it is not clear why this is the case.
Does anybode have an explanation for that?
Regars
vivkr
Re: MOS-capacitance of NMOS/PMOS
Reply #1 - Feb 19th, 2008, 11:08pm
Hi Berti
Could you post a snapshot of your setup?
Vivek
Berti
Reply #2 - Feb 19th, 2008, 11:59pm
Sure, the voltage source is sweeped from -vdd to +vdd and the capacitance measured accordingly.
I also replaced the NMOS by a PMOS. Therefore inversion happens for -vin for PMOS and +vin for NMOS,
considering the figure from the first post.
Reply #3 - Feb 22nd, 2008, 6:43am
I would think the poly gate and substrate doping levels are going to be different.  Particularly on the poly gate, there's a poly depletion effect that could change the effective "d" in the eps A / d formula for capacitance.
Berti
Reply #4 - Feb 24th, 2008, 10:13pm
Thanx Geoffrey, sounds reasonable.
vivkr
Reply #5 - Feb 25th, 2008, 2:59am
Geoffrey_Coram wrote on Feb 22nd, 2008, 6:43am:
Hi Geoffrey,
Would this also lead to the "buried channel" effect in 1/f noise? The channel must be significantly below the surface
to cause a visible change in "d". I would imagine that 1/f noise drops a lot. What do you think?
Berti: Does your PMOS have much less noise in output current for a given DC current at a given size compared to the NMOS?
Vivek
Reply #6 - Feb 25th, 2008, 4:34am
vivkr wrote on Feb 25th, 2008, 2:59am:
I have heard that PMOS devices have lower 1/f because of the buried channel.  Probably the peak concentration of the NWELL channel implant for the PMOS is below the surface (I don't have a sense for how far), whereas the NMOS channel is the P substrate and is evenly spread (except for pocket implants?).
Berti
Reply #7 - Feb 25th, 2008, 6:41am
Hi Vivek,
NMOS and PMOS show very similar flicker-noise. That's also agrees to measurement
results from publications about 1/f-noise using a 130nm technolgy.
