Apr 27th, 2024, 10:49pm
Measuring Free Run LC VCO's Phase Noise (Read 3564 times)
neoflash
Mixed-Signal
Designer
Mar 02nd, 2008, 3:24am
It seems difficult to measure free running LC-VCO's phase noise with E5052-A.
During measuring, it shows quick variation in low frequency band. Any experience with it?
Ryan Cheung
Re: Measuring Free Run LC VCO's Phase Noise
Reply #1 - Apr 30th, 2008, 8:43pm
If the measured VCO is biased from a regulator or something except a pin from the out-chip supply, it may encountered the problem you have mentioned. Based on my experience, there are 2 methods you can try:
1. tuning the IF gain of E5052 to a lower value;
2. using the 'supply voltage' of the E5052 to bias the VCO and adding a huge capacitor at the supply node if necessary.
Miconos
Reply #2 - Jun 29th, 2008, 12:17am
Give more details:
is it on Silicon?
how do you regulate and bias your VCO?
do you have a VCO buffer?
