jimmy
Hi, Ken mentioned in http://www.designers-guide.org/Forum/YaBB.pl?num=1036525104/0, that what we got by clicking "pnoise" button when using "noisetype=source" for driven circuit is actually not phase noise but L = Sv(df)/(2*V1^2), Sv(df) is the voltage noise power density. Now I am confused how can I get phase noise in such case. Basically what I am trying to do is to compare the phase noise/jitter simulation results between different noise type settings (modulated, source, jitter, time domain). For modulated and source noise types, I should be able to get phase noise, then I can convert it to jitter; For jitter and timedomain noise types, I should be able to get jitter then convert to phase noise. Either way, the numbers I get should be the same (or very close), right? Thanks a lot,
