Aug 15th, 2024, 12:07pm
phase noise calculation using spectre (Read 4212 times)
patwarga
May 08th, 2008, 8:05am
hi,
i am trying to calculate the phase noise for a frequency divider that we have designed in cadence.
when i look for any tutorial on the web, all of them talk about phase noise of an oscillator.
i got one document on the designer's guide though - which talks about the phase noise model of a divider.
it says that one should do pss on the divider and then the pnoise analysis.
but i am confused about what values do i need to give to different parameters like beat frequency, output harmonics etc. while doing the pss analysis
my pss analysis terminates due to error saying that it doesn't converge..
all i am looking for the steps (actually the babysteps) to do the pss and pnoise analysis on the divider with information about the values to be given in different boxes
i am using cadence spectre for the project.
can anyone please help me?
thanks
couragebo
Re: phase noise calculation using spectre
Reply #1 - May 27th, 2008, 5:47am
You can try the following:
beat frequency: divider's nominal output frequency
output harmonics: you mean the max. harmonic order? try the N*16 or plus. (N is the division order)
don't forget the tsab: the stablization time, usually 3-10 periods of beat frequency is suffisant.
Miconos
Reply #2 - Jun 29th, 2008, 12:42am
Agree with the above with one more thing:
Sometimes playing with Tstab by a fraction of the cycle time can help dramatically. you don't want to be near the edges of the squared signal.
