Aug 15th, 2024, 2:24pm
Verilog-A model of VCO for PSS/PNOISE simulation (Read 13252 times)
pholm
Santa Cruz
Jun 13th, 2008, 11:41am
I'm looking for a Verilog-A model of a VCO with frequency dependent phase noise that runs in pss/pnoise.  The model needs to output a voltage waveform to drive the PFD/CP circuit in my top level PLL.  All I can find in the various references here are models designed for transient analysis or use in a linearized PLL model.  The end goal is to make a VCO/divider combination so I can run a full pss/pnoise sim of my PLL with transistor level models of everything except the VCO.  The frequency dependent noise is achievable, I think, through use of the flicker_noise function.
Would very much appreciate some help.
Thanks!
Peter
Ryan Cheung
Re: Verilog-A model of VCO for PSS/PNOISE simulati
Reply #1 - Jun 13th, 2008, 9:15pm
It seems that the Verilog-A model cannot be run in pss/pnoise simulation.
Reply #2 - Jun 13th, 2008, 11:12pm
Perhaps Listing 1 in http://www.designers-guide.org/Analysis/rf-sim.pdf is what you are looking for.
sandman
Re: Verilog-A model of VCO for PSS/PNOISE simulation
Reply #3 - Jul 8th, 2008, 8:54am
Please correct me if I'm wrong,  but from what I understand the PSS simulations cannot be performed with hidden state variables in the verilog-a code/model, that come from using the PRN generators in the noise functions. Apparently when such PRN generators are used, the PSS simulation cannot find a steady state (SS) solution to define the VCO's waveform.
Cheers.
Reply #4 - Jul 8th, 2008, 9:38am
Using random number generators to model phase noise in an oscillator is fundamentally incompatible with PSS not because of hidden state, but because the result is not periodic.
However, the question originally involved using the flicker_noise function. In this case the noise is confined to the small-signal PNoise analysis and is not present during the PSS analysis.
