trond
Thanks for the prompt reply Stefan.
I simulated over 5000 periods. I am running a longer simulation just now to see if it makes a difference. In the transient simulation I did not have the transient noise option enabled.
1) Should I do so? If so, the pss+pnoise analysis does not introduce random noise, does it?
At the moment I only have an RCL network on the power supply and all resistors have noise as well.
2) In theory the results should be pretty much identical, should they not?
