May 11th, 2024, 1:29am
Can not match pnoise/jitter results (Read 3436 times)
jimmy
Apr 02nd, 2008, 10:39am
Ken mentioned in  http://www.designers-guide.org/Forum/YaBB.pl?num=1036525104/0,
that what we got by clicking "pnoise" button when using "noisetype=source" for driven circuit is actually not phase noise but L = Sv(df)/(2*V1^2), Sv(df) is the voltage noise power density. Now I am confused how can I get phase noise in such case. Basically what I am trying to do is to compare the phase noise/jitter simulation results between different noise type settings (modulated, source, jitter, time domain). For modulated and source noise types, I should be able to get phase noise, then I can convert it to jitter; For jitter and timedomain noise types, I should be able to get jitter then convert to phase noise. Either way, the numbers I get should be the same (or very close), right?
Thanks a lot,
rfmems
Re: Can not match pnoise/jitter results
Reply #1 - Apr 26th, 2008, 2:09am
there is no accurate formula to convert phase noise to jitter, not to mention from jitter to phase noise. So how did you do the conversion?
Miconos
Reply #2 - Jun 29th, 2008, 12:29am
Jitter can be translated to integrated phase noise and vice versa. is that what you are looking for
