Jul 18th, 2024, 3:32am
Recommendation of Discrete Cost Effective Balun (Read 2796 times)
Mar 13th, 2008, 3:31am
Hi.
I'm now studying cost effective balun using discrete L and C.
My TX PA outputs are open drain of differential pair.
So I have to feed Vdd via external inductor or resistor.
And I have to share TX differential pins with RX differential LNA inputs.
Is there any good cost effective balun structure using discrete L and C for this purpose ?
ACWWong
Oxford, UK
Re: Recommendation of Discrete Cost Effective Balu
Reply #1 - Mar 13th, 2008, 3:46am
An LC "bridge" configuration should be ok if you only need narrow band, and the LNA input Z and TX output Z are similiar (i.e. same balun impedance tranform useable for both rx and tx modes)
i quick google gives
http://www.odyseus.nildram.co.uk/RFMicrowave_Circuits_Files/Balun%20Design.pdf
and the first method is the lumped LC configuration i'm suggesting.
hope it helps
Reply #2 - Mar 14th, 2008, 1:03am
Thanks for valuable information.
