Aug 15th, 2024, 2:29pm
Flicker noise of active device in LC VCO (Read 4171 times)
jlee
Mar 23rd, 2008, 7:27pm
Dear guys,
I have two questions about flicker noise upconversion of active device (negative transconductance) in LC VCO.
1. For close-in phase noise (1k ~ 100k), it is observed that the noise contribution is dominated by upconverted flicker noise in active device. My question is how can we explain this observation in physical insight? Is it  pure AM-PM action by nonlinear cap or harmonic mixing (say 2nd harmonic) ? How to prove that by simulation?
2. In "A 1.5V, 1.7mA 700 MHz CMOS LC Oscillator with no upconverted flicker noise" by K. Hoshino, it is proposed that an inductor inserted at active device source can help to improve close-in phase noise. Why such an inductor can achieve that?
Jason
emad
Cairo, Egypt
Re: Flicker noise of active device in LC VCO
Reply #1 - Mar 25th, 2008, 2:02am
Flicker noise up-conversion mechanisms  are fairly complex. They are mostly based on AM-FM conversion through the varactor and other non-linear caps. However, the capacitance at the common mode point also plays a role that is not AM-FM based. It works more on shifting the switching edge back and forth so it is PM not FM.
The premise in Hoshino's paper is different. The noise filter tunes out the capacitance at the common mode point at a single frequency. It tries to widen this tune-out range by capacitance switching. The noise of the noise filter allows you to inflate the size of the current source (hence reducing its flicker noise) without fear of loading the common mode point.
Emad
jlee
Reply #2 - Mar 26th, 2008, 1:46am
Thank you, emad.
Do you think it is a robust way to get excellent close-in phase noise by noise fliter (inducotr and cap at active device source) over process and temperature?
Jason
emad
Cairo, Egypt
Reply #3 - Apr 1st, 2008, 12:58am
It is good for bias flicker noise but it does not dramatically improve flicker of the switches. It will improve pushing though.
Emad
jlee
Reply #4 - Apr 9th, 2008, 7:00pm
Thanks for your input.
Considering only flicker noise from differential pairs exists in VCO, which structrure is more attractive to get flicker-free phase noise, NMOS only or complementary (PMOS only is not selected for its low effective Gm for a given current)?
Jason
