9patch
That's because Calibre uses loop inductance to calculate inductance. You would need to set the power and ground names to be all of the nets that you have for power and ground, for example, VDD and VSS. If you don't want to use loop inductance, I believe that you can use the SVRF statement PEX DIFFERENTIAL PAIR, which will do partial inductance.
