Jul 16th, 2024, 12:20pm
how to implement 1/(1-a*z^(-1)) with SC circuit (Read 3750 times)
baohulu
china
Mar 31st, 2008, 5:25am
hi, all
 in SC circuit, we can always see the implement of a/(1-z^(-1)), while, can it implement 1/(1-a*z^(-1)), where a is not equal to 1?
 if there is some reference, please tell me
 thanks
Re: how to implement 1/(1-a*z^(-1)) with SC circui
Reply #1 - Mar 31st, 2008, 5:51am
baohulu wrote on Mar 31st, 2008, 5:25am:
hi, all
thanks
For me, complete integral a/(1-z^(-1)) is rare.
Rather incomplete integral 1/(1-a*z^(-1)) is common.
So realize it as incomplete integral.
Also we can realize "a" as complex number.
« Last Edit: Mar 31st, 2008, 8:36am by pancho_hideboo »
baohulu
china
Reply #2 - Mar 31st, 2008, 6:49pm
then how to implement it ? use input forward feedthrough to the input?
however, in the SC bandpass sigma delta adc, the resonator is usually implemented use the a/(1-z^(-1)) or a*z^(-1)/(1-z^(-1)), rather than 1/(1-a*z^(-1)) , and why?
Berti
Reply #3 - Mar 31st, 2008, 11:14pm
a/(1-z^(-1)) or a*z^(-1)/(1-z^(-1)) are integrators without and with delay, respectively. Integrators are relatively straight-forward
to be implemented as a SC circuit.
1/(1-a*z^(-1)) is also called leaky-integrator (for a<1). In fact, most circuit implementations have such a transfer function. Due to
infinte gain of amplifiers etc., charge-transfer won't be ideal and you will loose a small amount of charge during each phase. This charge-loss will result in a
a transfer function equal to 1/(1-a*z^(-1)), where a can be approximated as 1-1/(Gain of amplifier).
Hope this helps, cheers
Reply #4 - Mar 31st, 2008, 11:54pm
baohulu wrote on Mar 31st, 2008, 6:49pm:
The followings are not best reference, but might be helpful for you.
In [2], 1st IIR is implemented as incomplete integral(leaky integral).
[1] AUTHORS: Stephen A. Jantzi, Kenneth W. Martin, and Adel S. Sedra
TITLE: Quadrature bandpass ΔΣ modulation for digital radio
ISSUE: IEEE Journal of Solid-State Circuits, vol. 32, pp. 1935 - 1950, December 1997
[2] TITLE: A discrete-time bluetooth receiver in a 0.13μm digital CMOS process
ISSUE: IEEE International Solid-State Circuits Conference, vol. XLVII, pp. 268 - 269, February 2004
See above [1].
« Last Edit: Apr 1st, 2008, 10:33am by pancho_hideboo »
