May 7th, 2024, 1:51pm
help needed on wideband matching (Read 6523 times)
chase.ng
penang/malaysia
Mar 31st, 2008, 5:28pm
I am not very familiar with impedance matching. I have a circuit with its input impedance that is a low pass equivalent to 1k // 2pF. It is connected to a 50 ohm source via a 50 ohm tline. I would like to match the 1k // 2pF input to 50 ohm so that the source always sees a 50 ohm load. The problem is I need the match to work from 1 GHz to 2 GHz. Any idea? Please assist.
thanks and regards,
chase
Chase
View Profile chase.ng   IP Logged
Re: help needed on wideband matching
Reply #1 - May 4th, 2008, 11:53am
chase.ng wrote on Mar 31st, 2008, 5:28pm:
I don't know what you mean by "a low pass equivalent to 1k // 2pF".
But if it means simple parallel RC impedance, simple resistive matching is most reasonable, I think.
Or do you mean an equivalent low pass representation of bandpass impedance ?
Reply #2 - May 5th, 2008, 12:40pm
From Bode-Fano criteria for Parallel RC load matched with reactive networks,
the best reflection coefficient averaged over 1GHz ~ 2GHz is like following.
    Averaged_Gamma >= exp{-1/(2*BW*R*C)}, Here BW=2GHz-1GHz=1GHz, R=1kOhm, C=2pF.
Then Averaged_Gamma_dB >= -2.17dB
dB(S(5,5)) can almost achieve this theoretical limit.
« Last Edit: May 6th, 2008, 7:10am by pancho_hideboo »
chase.ng
penang/malaysia
Reply #3 - May 10th, 2008, 7:36pm
Thanks for your help. I am still quite new to the RF matching so I would need some time to digest the matching network you provided. Yes. I mean it is a simple parallel RC.
But a few question pop up in my mind that I hope you can shed some light. Isn't that the best matching condition will yield very small S11 number? -2.17 still seems too high. Does that means i have no choice but to use resistive matching?
Many thanks...  :D
Chase.
Chase
Reply #4 - May 14th, 2008, 7:40am
chase.ng wrote on May 10th, 2008, 7:36pm:
It depends on your applications.
If you have importance in reflection, this return loss is too large.
But if you have importance in transmitted power, this return loss could be acceptable.
This also depends on your applications.
If you invoke hybrid matching of resistive and reactive, you can achieve better S11.
What application do you intend to design ?
What signal scheme do you apply ?
Is there frequency channel control signal. e.g. for PLL ?
Is there any possibility to change matching networks using such control signal ?
Varactor, Pin-diode, etc...
