dandelion
Hi, I am deisgning an block which is PECl output. I found my process provide an NPN Tr and so I intend to use it to implement the PECL level. The NPN Tr is N+/P/NWELL topology. The base is located in the NWELL.
I communicated with the foundr, they said although this device is availble, it is not tested ever, so they can not guarantee if it have any risks. They said the beta of this device is 20 or so.
Would you pls. give any advice in using this device? Any risks ? What about its permance in mass production?
